View the area advertisements and other information in the LSDB to ensure correct OSPF operations.
Switch(config-ospf)#show ip ospf lsdb
OSPF LSDB - GlobalRouter
Router Lsas in Area 0.0.0.0
LSTYPE LINKSTATEID ADV_ROUTER AGE SEQ_NBR CSUM
Router 192.0.2.0 192.0.2.0 617 0x80000031 0xeafd
Router 198.51.100.0 198.51.100.0 1033 0x80000030 0xa5f2
Network Lsas in Area 0.0.0.0
Network 100.1.1.2 192.0.2.0 617 0x8000002f 0xd038
Summary Lsas in Area 0.0.0.0
AsSummary Lsas in Area 0.0.0.0
NSSA Lsas in Area 0.0.0.0
AsExternal Lsas
LSTYPE LINKSTATEID ADV_ROUTER ETYPE METRIC ASE_FWD_ADDR AGE SEQ_NBR CSUM
Variable definitions
The following table defines parameters for the show ip ospf lsdb command.
Variable |
Value |
adv_rtr {A.B.C.D} |
Specifies the advertising router. |
area {A.B.C.D} |
Specifies the OSPF area. |
detail |
Provides detailed output. |
lsa-type <0-7> |
Specifies the link-state advertisement type in the range of 0–7. |
lsid {A.B.C.D} |
Specifies the link-state ID. |
vrf WORD<1-16> |
Specifies a VRF by name. |
vrfids WORD<0-512> |
Specifies a range of VRF IDs. |
