Switch:1#show ipv6 source-guard interface gigabitEthernet 4/1
Slot/Port Source Guard Number of IPv6 Address
Mode address allowed overflow count
4/1 Enabled 4 0
Switch:1#show ipv6 source-guard interface enabled
4/1 Enabled 4 0
4/2 Enabled 9 0
The following table defines parameters for the show ipv6 source-guard interface gigabitEthernet command.
Variable |
Value |
enabled |
Displays IPSG configuration on all IPSG enabled interfaces. |
gigabitEthernet {slot/port[/sub-port] [-slot/port[/sub-port]] [,...]} |
Displays IPSG configuration on the specified interface. Identifies the slot and port in one of the following formats: a single slot and port (slot/port), a range of slots and ports (slot/port-slot/port), or a series of slots and ports (slot/port,slot/port,slot/port). If the platform supports channelization and the port is channelized, you must also specify the sub-port in the format slot/port/sub-port. |
