Use this procedure to display RADIUS CoA Disconnect statistics.
- Click RADIUS CoA.
- Click the Disconnect Stats tab.
Disconnect Stats Field Descriptions
Use the data in the following table to use the Disconnect Stats tab.
Name |
Description |
DisconRequests |
Specifies the number of RADIUS disconnect requests received from this Dynamic Authorization Client. This also includes the RADIUS disconnect requests that have a Service-Type attribute with a value of Authorize Only. |
DisconAuthOnlyRequests |
Specifies the number of RADIUS disconnect requests that include a Service-Type attribute with a value of Authorize Only received from this Dynamic Authorization Client. |
DupDisconRequests |
Specifies the number of duplicate RADIUS Disconnect-Request packets received from this Dynamic Authorization Client. |
DisconAcks |
Specifies the number of RADIUS Disconnect-ACK packets sent to this Dynamic Authorization Client. |
DisconNaks |
Specifies the number of RADIUS Disconnect-NAK packets sent to this Dynamic Authorization Client. This includes the RADIUS Disconnect-NAK packets sent with a Service-Type attribute with a value of Authorize Only and the RADIUS Disconnect-NAK packets sent because no session context was found. |
DisconNakAuthOnlyRequests |
Specifies the number of RADIUS Disconnect-NAK packets that include a Service-Type attribute with a value of Authorize Only sent to this Dynamic Authorization Client. |
DisconNakSessNoContext |
Specifies the number of RADIUS Disconnect-NAK packets sent to this Dynamic Authorization Client because no session context was found. |
DisconUserSessRemoved |
Specifies the number of user sessions removed for the disconnect requests received from this Dynamic Authorization Client. Depending on site-specific policies, a single disconnect request can remove multiple user sessions. In cases where this Dynamic Authorization Server has no knowledge of the number of user sessions that are affected by a single request, each such disconnect request counts as a single affected user session only. |
MalformedDisconRequests |
Specifies the number of malformed RADIUS Disconnect-Request packets received from this Dynamic Authorization Client. Bad authenticators and unknown types are not included as malformed disconnect requests |
DisconBadAuthenticators |
Specifies the number of RADIUS Disconnect-Request packets that contain an invalid Authenticator field received from this Dynamic Authorization Client. |
DisconPacketsDropped |
Specifies the number of incoming disconnect requests from this Dynamic Authorization Client silently discarded by the server application for some reason other than malformed packets, bad authenticators, or unknown types. |
UnknownTypes |
Specifies the number of incoming requests that have an invalid ID type. |
