Use this procedure to display information about the learned multicast groups in the cache.
- In the navigation pane, expand the following folders: .
- Click IPv6 MLD.
- Click the Cache tab.
MLD cache field description
Use the data in the following table to use the Cache tab.
| Field | Description |
| Address | The IPv6 multicast group address for which this entry contains information. |
| IfIndex | Indicates the internetwork-layer interface for which this entry contains information for an IPv6 multicast group address. |
| LastReporter | Indicates the source IPv6 address of the last membership report received for this IPv6 Multicast group address on this interface. If membership report is not received, the value is 0::0 |
| ExpiryTime | Indicates the minimum amount of time remaining before the entry ages out. |
