Use this procedure to configure FA globally or view existing FA global configuration.
Fabric Attach Globals Field Descriptions
Use the data in the following table to use the Fabric Attach Globals tab.
Name |
Description |
Service |
Enables or disables Fabric Attach service globally. The default is enable. |
ElementType |
Specifies the Fabric Attach element type. The supported element type is Fabric Attach Server. |
AsgnTimeout |
Specifies the Fabric Attach assignment time-out in seconds. The range is 45 to 480 seconds. The default is 240 seconds. |
ProvisionMode |
Specifies the Fabric Attach provision mode. The supported provision mode is SPB. |
DiscTimeout |
Specifies the Fabric Attach discovery time-out in seconds. The range is 45 to 480 seconds. The default is 240 seconds. |
Clear FA Statistics |
Clears Fabric Attach statistics. |
ClearGlobalErrorCounters |
Clears Fabric Attach global error counters. Disabled by default. |
