Use the following procedure to install the Root CA certificate obtained offline.
- Click System Log.
- Click Root Certificate Table tab.
- Click Insert.
- In the Filename field, enter the filename obtained offline from the CA.
- In the Action field, select the action.
- Click Insert.
Root Certificate Table field description
Use the data in the following table to use the tab.
Name |
Description |
Filename |
Specifies the certificate filename obtained offline from the Root Certificate Authority. |
Action |
Specifies the action to be performed on Root CA.
The system displays the Conversion Fail if the execution of the action fails. |
