Perform this procedure to configure Egress Tunnel Shaping on a logical interface.
Use the data in the following table to use the vlan members command.
Variable |
Value |
| remove <1-4059> |
{slot/port[/sub-port][-slot/port[/sub-port]][,...]} |
Identifies the slot and port in one of the following formats: a single slot and port (slot/port), a range of slots and ports (slot/port-slot/port), or a series of slots and ports (slot/port,slot/port,slot/port). If the platform supports channelization and the port is channelized, you must also specify the sub-port in the format slot/port/sub-port. |
Use the data in the following table to use the spbm command.
Variable |
Value |
<1-100> |
Specifies the Shortest Path Bridging MAC (SPBM) instance ID. Creates the SPBM instance. Only one SPBM instance is supported. |
Use the data in the following table to use the spbm command to create a system nickname for an SPBM instance.
| Variable | Value |
<1-100> |
Specifies the Shortest Path Bridging MAC (SPBM) instance ID. Creates the SPBM instance.Only one SPBM instance is supported. |
nick-name x.xx.xx |
Specifies the system nickname (2.5 bytes in the format ). |
Use the data in the following table to use the spbm command to assign Backbone VLANs to the SPBM instance.
| Variable | Value |
<1-100> |
b-vid {vlan-id[-vlan-id][,...]} |
Specifies the VLANs to add to the Shortest Path Bridging MAC (SPBM) instance as Backbone VLANs (B-VLANs). Sets the IS-IS SPBM instance data VLANs. |
primary <1-4059> |
Specifies the primary B-VLAN by VLAN ID. |
Use the data in the following table to use the sys-name command.
| Variable | Value |
WORD<0-255> |
Specifies the system name. |
Use the data in the following table to use the is-type command.
| Variable | Value |
l1 |
Configures the router type as Level 1 Intermediate-System-to-Intermediate-System (IS-IS). |
Use the data in the following table to use the manual-area command.
| Variable | Value |
xx.xxxx.xxxx...xxxx |
Configures the manual area in a size up to 13 octets. The current release supports one area. For Intermediate-System-toIntermediate-System (IS-IS) to operate, you must configure at least one area. |
Use the data in the following table to use the vlan create command.
| Variable | Value |
<1-4059> |
type spbm-bvlan |
Specifies the VLAN type as the backbone VLAN (B-VLAN) for Shortest Path Bridging MAC (SPBM). |
Use the data in the following table to use the interface GigabitEthernet command.
| Variable | Value |
Use the data in the following table to use the brouter port command.
| Variable | Value |
| {slot/port[/sub-port]} |
Identifies a single slot and port. If the platform supports channelization and the port is channelized, you must also specify the sub-port in the format slot/port/sub-port. |
| vlan <1-4059> |
subnet <A.B.C.D/X> |
Assigns an IP address and mask for the management port. |
mac-offset <MAC-offset> |
Specifies a number by which to offset the MAC address from the chassis MAC address. This ensures that each IP address has a different MAC address. If you omit this variable, a unique MAC offset is automatically generated. Different hardware platforms support different ranges. To see which range is available on the switch, use the CLI command completion Help. |
Use the data in the following table to use the ip-tunnel-source-address command.
| Variable | Value |
{A.B.C.D} |
Specifies the IS-IS IPv4 tunnel source address. |
Use the following table to use the logical-intf command.
| Variable | Value |
isis <1–255> |
Specifies the ISIS logical interface ID. |
dest-ip {A.B.C.D} |
Specifies the destination IP address for the logical interface. |
name WORD <1–64> |
Specifies the administratively-assigned name of this logical interface, which can be up to 64 characters. |
| mtu
<750–9000> Note: Exception: only
supported onXA1400
Series
Specifies the Maximum Transmission Unit (MTU) size for each packet. Default mtu value is 1950. |
Use the data in the following table to use the egress-shaping-rate command.
Variable |
Value |
<1-1000> |
Specifies the shaper bandwidth in Mbps. |
Egress Tunnel Shaping Configuration Example
The following is an example of an Egress Tunnel Shaping configuration.
SPBM Configuration
Switch> enable Switch# config terminal Switch(config)# vlan members remove 1 1/8 Switch(config)# spbm Switch(config-isis)# router isis Switch(config-isis)# spbm 1 Switch(config-isis)# spbm 1 nick-name 1.11.40 Switch(config-isis)# spbm 1 b-vid 2,3 primary 2 Switch(config-isis)# exit Switch(config)# router isis Switch(config-isis)# sys-name XA1400 Switch(config-isis)# is-type l1 Switch(config-isis)# manual-area c0.2000.0000.00 Switch(config-isis)# exit Switch(config)# vlan create 2 type spbm-bvlan Switch(config)# vlan create 3 type spbm-bvlan
Fabric Extend Configuration
Switch(config)# router isis enable Switch(config)# interface GigabitEthernet 1/8 Switch(config-if)# brouter port 1/8 vlan 2500 subnet 192.0.2.1/255.255.255.0 mac-offset 0 Switch(config-if)# exit Switch(config)# router isis Switch(config-isis)# ip-tunnel 192.0.2.1 Switch(config-isis)# exit
Switch(config)# logical-intf isis 1 dest-ip 192.0.2.2 name "bang" Switch(config-isis-1)# isis Switch(config-isis-1)# isis spbm 1 Switch(config-isis-1)# isis enable Switch(config-isis-1)# egress-shaping-rate 500 Switch(config-isis-1)# exit
