Use statistics to help you monitor OSPF performance.
View the OSPF interface statistics:
Switch:1#show ip ospf ifstats
                    OSPF Interface Statistics - GlobalRouter
                ---HELLOS---- ---DBS--- -LS REQ-- --LS UPD--- --LS ACK---
INTERFACE       RX     TX     RX   TX   RX   TX   RX    TX     RX    Tx
192.0.2.3      76035  76355  33   32   4    9    2483  2551  2525  1247
192.0.2.8      76038  76349  0    0    0    0    0     0     0     0
Variable definitions
The following table defines parameters for the show ip ospf ifstats command.
 Variable  |
 Value  |
 <1-4059>  |
 Specifies the VLAN ID in the range of 1 to 4059. By default, VLAN IDs 1 to 4059 are configurable and the system reserves VLAN IDs 4060 to 4094 for internal use. On switches that support the vrf-scaling and spbm-config-mode boot configuration flags, if you enable these flags, the system also reserves VLAN IDs 3500 to 3998. VLAN ID 1 is the default VLAN and you cannot create or delete VLAN ID 1.  |
 detail  |
 Displays the details of the OSPF.  |
 mismatch  |
 Specifies the number of times the area ID is not matched.  |
 vrf WORD<1-16>  |
 Specifies a VRF by name.  |
 vrfids WORD<0-512>  |
 Specifies a range of VRF IDs.  |
