Enable Ethernet statistics collection for RMON.
- Click Control.
- Click the Ethernet Statistics tab.
- Click Insert.
- Next to the Port box, click the ellipsis (...) button.
- Select a port.
- Click OK.
- In the Owner box, type the name of the owner entity.
- Click OK.
- Click Insert.
Ethernet Statistics Field Descriptions
Use the data in the following table to use the Ethernet Statistics tab.
| Name | Description |
| Index | Uniquely identifies an entry in the Ethernet Statistics table. The default is 1. |
| Port | Identifies the source of the data that this etherStats entry is configured to analyze. |
| Owner | Specifies the entity that configured this entry and therefore uses the assigned resources. |
