Configure a non-DvR backbone edge bridge (BEB) to join the DvR backbone so that it can receive redistributed DvR host routes from all DvR Controllers in the SPB network.
On a non-DVR BEB, the redistributed host routes from the DvR backbone are not automatically installed in the IP routing table. To utilize the backbone host routes to optimize traffic forwarding (forwarding in the data plane), you must explicitly configure an IS-IS accept policy with a backbone route policy using the command accept backbone-route-map <route-map-name>, and specifying a suitable route-map to select the list or range of DvR backbone host routes to be installed in the routing table.
For more information on configuring an IS-IS accept policy with a backbone route policy, see Configuring IS-IS Accept Policies.
enable
configure terminal
router isis
[no]|[default] backbone enable
show dvr backbone-members
show dvr backbone-members non-dvr-beb
show dvr backbone-entries
show isis
Switch3:1>enable
Switch3:1#configure terminal
Enter configuration commands, one per line. End with CNTL/Z.
Switch3:1(config)#router isis
Switch3:1(config-isis)#show dvr
NON DVR BEB Summary Info
Domain ID : 0
Domain ISID : 0
Backbone ISID : 16678216
Role : NON DVR BEB
My SYS ID : 00:00:82:84:40:00
Operational State : Up
Configure the non-DvR BEB to join the DvR backbone.
Switch3:1(config-isis)#backbone enable
Verify the configuration. View the DvR backbone members.
Switch3:1(config-isis)#show dvr backbone-members
DVR BB Members
System Name Nick-Name Nodal MAC Role Domain Id Area Area-Name
DVR-8284-D2-C1-40 0.82.40 00:00:82:84:40:00 NON-DVR-BEB 9999 HOME area-0.00.20
DVR-8284-D2-C2-41 0.82.41 00:00:82:84:41:00 Controller 9999 HOME area-0.00.20
Home: 2 out of 2 Total Num of DVR Backbone Members displayed
Switch3:1(config-isis)#show dvr backbone-members non-dvr-beb
DVR BB Members
Home: 1 out of 2 Total Num of DVR Backbone Members displayed
View the backbone DvR host routes that the non-DvR BEB receives from other Controllers in the SPB network.
Switch:1(config-isis)#show dvr backbone-entries
DVR Backbone-Entries
HOST L3VSN L2VSN DOMAIN
IP-ADDRESS MAC-ADDRESS ISID ISID ID ADV-CONTROLLER NEXT HOP AREA AREA-NAME
39.1.1.4 10:cd:ae:70:5d:01 401 10390 200 DVR-8284-D2-C2-41 DVR-8284-D2-C2-41 REMOTE area-0.00.30
39.2.1.4 10:cd:ae:70:5d:01 401 10391 200 DVR-8284-D2-C2-41 DVR-8284-D2-C2-41 REMOTE area-0.00.30
39.3.1.4 10:cd:ae:70:5d:01 401 10392 200 DVR-8284-D2-C2-41 DVR-8284-D2-C2-41 REMOTE area-0.00.30
39.4.1.4 10:cd:ae:70:5d:01 401 10393 200 DVR-8284-D2-C2-41 DVR-8284-D2-C2-41 REMOTE area-0.00.30
39.5.1.4 10:cd:ae:70:5d:01 401 10394 200 DVR-8284-D2-C2-41 DVR-8284-D2-C2-41 REMOTE area-0.00.30
39.6.1.4 10:cd:ae:70:5d:01 401 10395 200 DVR-8284-D2-C2-41 DVR-8284-D2-C2-41 REMOTE area-0.00.30
Remote: 6 out of 427 Total Num of DVR Backbone Routes displayed
View the IS-IS related information.
Switch3:1(config-isis)#show isis
ISIS General Info
AdminState : enabled
RouterType : Level 1
System ID : 00bb.0000.8121
Max LSP Gen Interval : 900
Metric : wide
Overload-on-startup : 20
Overload : false
Csnp Interval : 10
PSNP Interval : 2
Rxmt LSP Interval : 5
spf-delay : 100
Router Name : router_r1
ip source-address :
ipv6 source-address :
ip tunnel source-address :
Tunnel vrf :
ONA Port :
ip tunnel mtu :
Num of Interfaces : 3
Num of Area Addresses : 1
Inband Mgmt Clip IP :72.54.44.1
backbone :enabled
Dynamically Learned Area : 00.0000.0000
FAN Member : No
Hello Padding : enabled
Multi-Area OperState : disabled
