Configure Rapid Spanning Tree Protocol (RSTP) to reduce the recovery time after a network breakdown.
Configure RSTP:
Switch:1(config)# spanning-tree rstp forward-time 1000 hello-time 200 max-age 4000 pathcost-type bits16 priority 4096 tx-holdcount 10 version rstp group-stp enable
Use the data in the following table to use the spanning-tree rstp command.
Variable |
Value |
forward-time <400-3000> |
Configures the RSTP forward delay for the bridge in hundredths of a second. |
group-stp enable |
Enables or disables RSTP for a specific STG. Enter the no form of the command to disable RSTP for the STG (no spanning-tree rstp group-stp enable). |
hello-time <100-1000> |
Assigns the RSTP hello time delay for the bridge in hundredths of a second. |
max-age <600-4000> |
Assigns the RSTP maximum age time for the bridge in hundredths of a second. |
pathcost-type {bits16|bits32} |
Assigns the RSTP default pathcost version. The default is 32 bits. |
priority <0-61440> |
Assigns the RSTP bridge priority. |
tx-holdcount <1-10> |
Assigns the RSTP transmit hold count from 1 to 10. The default value is 6. |
version {rstp/stp-compatible} |
Sets the version to RSTP or STP compatible. |
