View UBoot Version and Status
This procedure only applies to 5420 Series and 5520 Series.
Use this information to verify the integrity of the software and hardware. A representative from Customer Support will instruct you to obtain this information when required.
- Select Chassis.
- Select the UBoot tab.
UBoot Field Descriptions
Use the data in the following table to use the UBoot tab.
| Name | Description |
DefaultVersion |
Displays the default UBoot version. |
AlternateVersion |
Displays the alternate UBoot version. |
VersionUsed |
Displays the UBoot version in use, either the default or alternate. |
TrustedDeliveryStatus |
Displays the status of the chain of trust image signature validation steps. |
