The following sections provide conceptual information about BFD configuration. For detailed procedural information about BFD configuration, see BFD Configuration using CLI and BFD Configuration using EDM.
To enable Bidirectional Forwarding Detection (BFD) between 2 peers:
To delete a BFD session, disassociate all applications with the BFD session, then administratively bring down the BFD session.
To successfully delete a BFD session, you must execute the commands in the following order:
If you change the above order of operations, the BFD session is not deleted.
