Perform this procedure to configure scheduled time intervals during which the switch will operate in low power state. This time interval can be for a week, weekend, or individual days.
You can configure a maximum of 84 entries in the Energy Saver schedule.
If you have previously enabled Energy Saver globally, you must disable it globally before creating a schedule.
If you have previously enabled Efficiency Mode, you must disable it before creating a schedule. You cannot change the default Efficiency Mode schedule entries when Efficiency Mode is enabled.
You must enable Energy Saver on every port affected by the schedule.
Switch:1>enable Switch:1# configure terminal Switch:1(config)#energy-saver schedule weekend 0735 activate Switch:1(config)#energy-saver schedule monday 0600 deactivate
What to do next
Enable Energy Saver globally.
The following table defines parameters for the energy-saver schedule command.
 Variable  |
 Value  |
 {activate | deactivate}  |
 Activates or deactivates the scheduled event.  |
 <hhmm>  |
 Specifies the hour and minutes to enable Energy Saver feature on the switch.  |
 {friday | monday | saturday | sunday | thursday | tuesday | wednesday | weekday | weekend}  |
 Specifies the day(s) to enable Energy Saver feature on the switch.  |
