View the Traceroute History
View the traceroute history to view the history of traceroute tests performed by the switch.
The traceroute probe history contains probe information for the hops in the routing path.
Troubleshooting using ping and traceroute (including Layer 2 ping and Layer 2 traceroute) is not supported on EDM. For more information, see VOSS Release Notes. As an alternative, use CLI.
- From the navigation pane, expand .
- Click Ping/Trace Route.
- Click the Trace Route Control tab.
- Select an entry.
- Click Trace Route Probe History.
Route Probe History Field Descriptions
Use the data in the following table to use the Trace Route Probe History tab.
Name |
Description |
OwnerIndex |
Identifies the Trace Route entry to which a probe result belongs. |
TestName |
Specifies the test name. |
Index |
Specifies the Index. |
HopIndex |
Indicates for which hop in a traceroute path the probe results are intended. |
ProbeIndex |
Specifies the index of a probe for a particular hop in a traceroute path. |
HAddrType |
Specifies the IP address type of the hop to which this probe belongs. |
HAddr |
Specifies the IP address of the hop to which this probe belongs. |
Response |
Specifies the cumulative results at any time. |
Status |
Specifies the status of the probe. |
LastRC |
When a new entry is added, the old entry is purged if the total number of entries exceeds the specified maximum number of entries in the Control Table Entry. |
Time |
Specifies the response time of the probe. |
