View the IPv6 RP set to see a list of rendezvous point addresses. View the parameters for troubleshooting purposes.
- In the navigation pane, expand the following folders: .
- Click IPv6 PIM.
- Click the RP Set tab.
RP Set field descriptions
Use the descriptions in the following table to use the RP Set tab.
Name |
Description |
GroupAddress |
Specifies the IPv6 address of the multicast group. When combined with the group mask, this value identifies a group prefix for which the address is a static RP. |
GroupMask |
Specifies the address mask of the multicast group. When combined with the group address, this value identifies a group prefix for which the address is a static RP. |
Address |
Specifies the IPv6 address of the static RP. |
HoldTime |
Specifies the hold time of the static RP. The value is 0. |
ExpiryTime |
Specifies the minimum time remaining before the static RP is down. The value is 0. |
