This procedure only applies to the VSP 7400 Series.
Perform this procedure to view remote IS-IS adjacency information. The platform sends IS-IS Hello (IIH) packets to discover IS-IS neighbors and establish and maintain the IS-IS adjacency. The platform continues to send IIH packets to maintain the adjacencies that the system establishes. For two nodes to form an adjacency the B-VLAN pairs for the primary B-VLAN and secondary B-VLAN must match.
- Select IS-IS Remote.
- Select the Adjacency tab.
Adjacency Field Descriptions
Use the data in the following table to use the Adjacency tab.
| Name | Description |
| Interface | Specifies the remote IS-IS interface on which the adjacency is found. |
| Level | Indicates the level of the remote IS-IS interface (Level 1 [default] or Level 2). |
| State | Specifies the state of the adjacency:
| LastUpTime | Indicates when the adjacency most recently entered the state up, measured in hundredths of a second since the last re-initialization of the network management subsystem. Displays 0 if the adjacency has never been in state up. |
| NeighPriority | Specifies the priority of the neighboring Intermediate System to transition to the Designated Intermediate System. |
| HoldTimer | Specifies the holding time in seconds for this adjacency. This value is based on received IS-IS Hello (IIH) PDUs and the elapsed time since receipt. |
| NeighSysID | Specifies the system ID of the neighboring Intermediate System. |
| AdjHostName | Specifies the host name listed in the LSP. |
| ParallelActive | Specifies if the current adjacency among all the parallel adjacencies between two nodes is active. The values are:
