Create an MSDP peer to establish a peer relationship between the local MSDP enabled router and a
            peer in another domain.
Important
Do not enable more than 20 active peers.
Switch:1>enable
Switch:1#configure terminal
Switch:1(config)#ip msdp peer 21.0.0.2
Switch:1(config)#ip msdp peer 21.0.0.2 enable
Switch:1(config)#ip msdp peer remote-as 1
Variable definitions
The following table defines parameters for the ip msdp peer command.
| Variable | Value |
| {A.B.C.D} | Specifies the MSDP peer IP address. |
| WORD<0-11> | Specifies the AS number of the MSDP peer, 0-65535 (2-Byte AS) 0-4294967295 (4-Byte AS). |
