Use this procedure to view or configure FA I-SID-to-VLAN assignment information.
- Click Fabric Attach.
- Click the Assignment tab.
- If you make configuration changes, click Apply to save changes.
Assignments Field Descriptions
Use the data in the following table to use the Assignments tab.
Name |
Description |
IfIndex |
Specifies the interface identifier of the I-SID-to-VLAN assignment. |
Isid |
Specifies the I-SID value of the I-SID-to-VLAN assignment. |
Vlan |
Specifies the VLAN ID component of the I-SID-to-VLAN assignment. |
State |
Specifies the current state of the I-SID-to-VLAN assignment. It can be one of the following values:
Origin |
Specifies the origin information of the I-SID-to-VLAN assignment. |
