Use this procedure to configure a client to allow processing of dynamic session changes.
You must enable EAPOL globally and at the port level.
You must enable RADIUS dynamic extensions commands processing at the port level.
- Click RADIUS CoA.
- Click Global.
- Click Insert.
- In the Address field type a client address.
- Optional: In the UdpPort field, type a value for client port.
- Optional: In the Secret field, type a value for the secret key.
- Select the Enable checkbox to enable dynamic session processing for the client.
- Click Insert.
Global field descriptions
Use the data in the following table to use the Global tab.
| Name | Description |
| AddressType | Specifies the type of address contained in the corresponding instance of a RADIUS Dynamic Authorization Client configured in this entry. |
| Address | Specifies the internet address of a RADIUS Dynamic Authorization Client configured in this entry. |
| UdpPort | Specifies the UDP port number the server/NAS listens on for requests from the RADIUS Dynamic Authorization Client configured in this entry. |
| Secret | Specifies the secret key shared between the RADIUS Dynamic Authorization Client and Server. Note that when this object is retrieved, it's value will always by a zero-length octet string. |
| Enable | Enable processing of dynamic session changes. |
