View the port egress CoS queue statistics. The system displays the statistics of the forwarded packets and bytes, and the dropped packets and bytes.
If you disable rate limiting on queue 6, bandwidth is shared based on the weights from queues 0 through 6. Based on equal weights assigned for queues 4 through 6, equal amounts of traffic egress queues 4 through 6. The system displays Queue 6 to provide much lower throughput than 50% of port bandwidth.
Use the data in the following table to use the show qos cosq-stats interface <PT_PORT> command.
Variable |
Value |
<PT_PORT> |
PT indicates the slot number; PORT indicates the port number. |
