Use the following procedure to clear all IPv4 Multicast Source Discovery Protocol (MSDP) statistics for all peers or a specific peer.
The switch supports this command for local management VRF or global routing table (GRT). If you do not specify a VRF or VRF ID, the switch defaults to GRT.
Use the data in the following table to use the clear ip msdp statistics command.
| Variable | Value |
| vrf WORD<0–16> | Specifies a VRF instance by VRF name. |
| vrfids WORD<0–512> | Specifies the ID of the VRF. |
| {A.B.C.D.} | Specifies the IPv4 MSDP address for a specific peer. |
