Configure a static foreign source on a VRF. Configuration is done at the Controller.
- Click Set VRF Context view.
- Select a row and click Launch VRF Context view.
- Select a switch port in the Device Physical View tab.
- Click SPB-PIM-GW.
- Click the Controller-Foreign-Source tab.
- Click Insert.
- In the SourceAddress box, type the multicast foreign source IP address.
- In the GroupAddress box, type the group IP address.
- Click Insert.
Controller-Foreign-Source field descriptions
Use the data in the following table to use the Controller-Foreign-Source tab.
Name |
Description |
SourceAddress |
Specifies the source IP address from a foreign multicast domain. |
GroupAddress |
Specifies the multicast group IP address associated with the foreign source. |
GatewaySysId |
Displays the system ID of the node selected as the Gateway for this foreign source. GatewaySysId field will have a valid value if the Gateway is assigned to a source. If the Gateway is not assigned to a source the value is 0. |
GatewayHostName |
Displays the host name of the node selected as the Gateway for this foreign source. GatewayHostName field will have valid values if the Gateway is assigned to a source. If the Gateway is not assigned to a source the value is NULL. |
Type |
Displays the owner type for this source. |
Owner |
Displays the IP address of the MSDP peer if the foreign source is MSDP. |
