To configure the switch as CDP-compatible, you must enable the Industry Standard Discovery Protocol (ISDP) on a port, or ports, on the switch. To enable ISDP, you use the lldp cdp command.
If CDP is enabled, the interface accepts only CDP packets. Similarly, if CDP is disabled but LLDP is enabled, the interface accepts only LLDP packets.
To switch a port from CDP mode to LLDP mode, the LLDP status on that port must be txAndrx.
Do not enable CDP mode if you plan to use the port with an ONA or Fabric Attach.
enable
configure terminal
interface GigabitEthernet {slot/port[/sub-port][-slot/port[/sub-port]][,...]}
lldp cdp enable
no lldp cdp enable
Switch:1>enable Switch:1#configure terminal Switch:1(config)#interface GigabitEthernet 4/4 Switch:1(config-if)#lldp cdp enable
To switch a port from CDP mode to LLDP mode, LLDP status on that port must be txAndrx.
Switch:1>enable Switch:1#configure terminal Switch:1(config)#interface GigabitEthernet 4/4 Switch:1(config-if)#no lldp cdp enable
To shutdown LLDP or CDP on a port:
Switch:1>enable Switch:1#configure terminal Switch:1(config)#interface GigabitEthernet 4/4 Switch:1>(config-if)#no lldp status
