Use this procedure to view FA interface configuration.
The following example displays sample outputs for the show fa interface command.
Switch:1>en
Switch:1#show fa interface
Fabric Attach Interfaces
INTERFACE SERVER MGMT MGMT MSG AUTH MSG AUTH
STATUS ISID CVID STATUS KEY
Port2/10 enabled 0 0 enabled ****
Port4/6 enabled 0 0 enabled ****
Port4/11 enabled 0 0 enabled ****
Mlt2 enabled 0 0 enabled ****
4 out of 4 Total Num of fabric attach interfaces displayed
The following is a sample output for the show fa interface command for the port 2/10.
Switch:1#show fa interface port 2/10
1 out of 4 Total Num of fabric attach interfaces displayed
The following is a sample output for the show fa interface command for the MLT 2.
Switch:1#show fa interface mlt 2
Variable definitions
The following table defines parameters for the show fa interface port command.
Variable |
Value |
{slot/port[/sub-port] [-slot/port[/sub-port]] [,...]} |
Identifies the slot and port in one of the following formats: a single slot and port (slot/port), a range of slots and ports (slot/port-slot/port), or a series of slots and ports (slot/port,slot/port,slot/port). If the platform supports channelization and the port is channelized, you must also specify the sub-port in the format slot/port/sub-port. |
The following table defines parameters for the show fa interface mlt command.
Variable |
Value |
<1–512> |
The valid range for MLT ID. |
