Perform this procedure to view MACsec status.
MACsec status
MACsec encryption status
MACsec encryption cipher suite, if supported on your hardware platform
The associated Connectivity Association (CA) name
If you do not specify a port number, the information on all MACsec capable interfaces is displayed.
enable
show macsec status {slot/port[/sub-port] [-slot/port[/sub-port]] [,...]}
show macsec
The switch does not support replay protect.
View MACsec status:
Switch:1#show macsec status
MACSEC Port Status
MACSEC Encryption Replay Replay Encryption Cipher CA MKA-Profile
PortId Status Status Protect Protect W'dow Offset Suite Name Name
1/1 enabled disabled disabled -- none AES-128 SMLTCONN mkapro1
1/2 disabled disabled disabled -- none AES-128 Nil --
1/3 disabled disabled disabled -- none AES-128 Nil --
1/4 disabled disabled disabled -- none AES-128 Nil --
1/5 disabled disabled disabled -- none AES-128 Nil --
1/6 disabled disabled disabled -- none AES-128 Nil --
1/7 disabled disabled disabled -- none AES-128 Nil --
1/8 disabled disabled disabled -- none AES-128 Nil --
1/9 disabled disabled disabled -- none AES-128 Nil --
1/10 disabled disabled disabled -- none AES-128 Nil --
1/11 disabled disabled disabled -- none AES-128 Nil --
1/12 disabled disabled disabled -- none AES-128 Nil --
1/13 disabled disabled disabled -- none AES-128 Nil --
--More-- (q = quit)
View MACsec status on port 1/1:
Switch:1>show macsec status 1/1
MACSEC Port Status
1/1 enabled disabled disabled -- none AES-128 SMLTCONN mkaprof1
Display all MACsec information:
MACSEC Connectivity Associations Info
Connectivity Connectivity AN_Mode / Port
Association Name Association Key Hash TxKeyParity Members
caname33 d4433e901bae92d0cc472706f66cfc18 4AN / odd
All 1 out of 1 Total Num of Macsec connectivity associates displayed
MACSEC Port Status
1/1 disabled disabled disabled -- none AES-128 Nil
1/3 enabled enabled disabled -- ipv4Offset(30) AES-256 caname33
1/4 enabled enabled disabled -- ipv4Offset(30) AES-128 caname34
--More-- (q = quit)
