Ping commands and traceroute commands execute in Global Router (GRT) context by default. You can configure ping commands and traceroute commands to execute in management (mgmt) context or in Virtual Router Forwarding (vrf) context.
This procedure is not supported on VSP 8600 Series.
The following table defines parameters for the sys default-ping-context command.
The sys default-ping-context command is not supported on VSP 8600 Series.Variable | Value |
grt | Specifies Global Routing Table (grt) context as the default context for ping commands and traceroute commands. The default configuration is grt as the default context. |
mgmt | Specifies management (mgmt) context as the default context for ping commands and traceroute commands. The default configuration is grt as the default context. |
vrf | Specifies Virtual Router Forwarding (vrf) context as the default context for ping commands and traceroute commands. The default configuration is grt as the default context. |
