Displays the IS-IS logical interface IPsec ID and authentication keys.
Use the following procedure to display the IS-IS logical interface IPsec ID and authentication keys.
show isis logical-interface ipsec
Switch:1>show isis logical-interface ipsec
                          ISIS Logical Interface IPSec
ID   Auth-Method    Auth-Key   Responder-Only   Remote NAT IP  Auth-Key-Len Status Compression
1    RSA-SIG        ******     False            -              128          Enable  False
 1 out of 1 Total Num of Logical ISIS interfaces
                           IPSec Tunnel General Info
       IPSec tunnel source-ip-address :
                               ISIS IPSec Tunnels
ID     IPSec Dst Ip        TUNNEL_NEXT_HOP
                           PORT/MLT   VLAN      VRF
1      192.0.2.200          Port1/6    100       GlobalRouter
