This procedure only applies to 5520 Series and VSP 4900 Series.
Configure all of the ports on an installed Versatile Interface Module (VIM) to operate at the same speed.
Some VIMs must operate with all ports at the same speed, while others can operate with ports at different speeds. For more information, see VOSS Release Notes. You can configure VIM ports speed only on VIMs that must operate with all ports at the same speed.
Install the VIM before performing this procedure.
Use this procedure to configure the speed of all ports in a multi-port VIM to operate at either 10 Gbps or 25 Gbps.
- Select Chassis.
- Select the VIM tab.
- Select mbps10000 or mbps25000.
- Select Apply.
VIM Field Descriptions
Use the data in the following table to use the VIM tab.
| Name | Description |
| AdminSpeed |
 The default is 25 Gbps. |
