Configure a static foreign source on the global router. Configuration is done at the Controller. Statically configure foreign sources, such as streams in a Source Specific Multicast (SSM) group range that are not advertised by the foreign network through MSDP. Non-SSM range group multicast address streams are advertised by MSDP and do not need to be statically configured.
Switch:1>enable
Switch:1#configure terminal
Switch:1(config)#ip spb-pim-gw foreign-source 10.0.0.1 group 240.0.0.1
Variable definitions
The following table defines parameters for the ip spb-pim-gw command.
| Variable | Value |
| foreign-source{A.B.C.D} | Specifies the multicast foreign source IP address. |
| group{A.B.C.D} | Specifies the group IP address. |
