The following table defines parameters for the set ipsec command.
| Variable | Value |
| <1-255> | Specifies the unique ID for the IPsec tunnel. |
| admin-state <enable | disable> | Enables or disables IPsec on the specific IPsec tunnel. |
| egress-shaping-rate <1-1000> | Specifies the egress shaping rate for the IPsec tunnel. |
