Use this procedure to view IPsec statistics and counter values for each IPsec-enabled interface.
If you select an interface on the Stats tab, you can click Graph to graph particular statistics for that interface.
- Click IPSec.
- Click the Interface Stats tab.
Interface Stats Field Descriptions
Use the data in the following table to use the Interface Stats tab.
Name |
Description |
IfIndex |
Shows the interface index for which the statistic is captured. |
InSuccesses |
Specifies the number of ingress packets IPsec successfully carries. |
InSPViolations |
Specifies the number of ingress packets IPsec discards since boot time because of a security policy violation. |
InNotEnoughMemories |
Specifies the number of ingress packets IPsec discards since boot time because not enough memory is available. |
InAHESPReplays |
Specifies the number of ingress packets IPsec discards since boot time because the AH replay check fails. |
InESPReplays |
Specifies the number of ingress packets IPsec discards since boot time because the ESP replay check fails. |
InAHFailures |
Specifies the number of ingress packets IPsec discards since boot time because the AH authentication check fails. |
InESPFailures |
Specifies the number of ingress packets IPsec discards since boot time because the ESP authentication check fails. |
OutSuccesses |
Specifies the number of egress packets IPsec successfully carries since boot time. |
OutSPViolations |
Specifies the number of egress packets IPsec discards since boot time because a security policy violation occurs. |
OutNotEnoughMemories |
Specifies the number of egress packets IPsec discards since boot time because not enough memory is available since boot time. |
generalError |
Specifies a general error. |
InAhSuccesses |
Specifies the number of ingress packets IPsec carries because the AH authentication succeeds. |
OutAHSuccesses |
InESPSuccesses |
Specifies the number of ingress packets IPsec carries since boot time because the ESP authentication succeeds. |
OutESPSuccesses |
OutKBytes |
Specifies the total number of kilobytes on egress. |
OutBytes |
Specifies the total number of bytes on egress. |
InKBytes |
Specifies the total number of bytes on ingress. |
InBytes |
TotalPacketsProcessed |
Specifies the total number of packets processed. |
TotalPacketsByPassed |
Specifies the total number of packets bypassed. |
OutAHFailures |
Specifies the number of egress packets IPsec discards since boot time because the AH authentication check fails. |
OutESPFailures |
Specifies the number of egress packets IPsec discards since boot time because the ESP authentication check fails. |
InMD5Hmacs |
Specifies the number of inbound HMAC MD5 occurrences since boot time. |
InSHA1Hmacs |
Specifies the number of inbound HMAC SHA1 occurrences since boot time. |
InAESXCBCs |
Specifies the number of inbound AES XCBC MAC occurrences since boot time. |
InAnyNullAuth |
Specifies the number of inbound null authentication occurrences since boot time. |
In3DESCBCs |
Specifies the number of inbound 3DES CBC occurrences since boot time. |
InAESCBCs |
Specifies the number of inbound AES CBC occurrences since boot time. |
InAESCTRs |
Specifies the number of inbound AES CTR occurrences since boot time. |
InAnyNulEncrypt |
Specifies the number of inbound null occurrences since boot time. Used for debugging purposes. |
OutMD5Hmacs |
Specifies the number of outbound HMAC MD5 occurrences since boot time. |
OutSHA1Hmacs |
Specifies the number of outbound HMAC SHA1 occurrences since boot time. |
OutAESXCBCs |
Specifies the number of outbound AES XCBC MAC occurrences since boot time. |
OutInAnyNullAuth |
Specifies the number of outbound null authentication occurrences since boot time. |
Out3DESCBCs |
Specifies the number of outbound 3DES CBC occurrences since boot time. |
OutAESCBCs |
Specifies the number of outbound AES CBC occurrences since boot time. |
OutAESCTRs |
Specifies the number of outbound AES CTR occurrences since boot time. |
OutInAnyNullEncrypt |
Specifies the number of outbound null occurrences since boot time. Used for debugging purposes. |
