View and Delete Debug Files
Use this procedure to view and delete debug files.
Delete debug files to free space in the intflash, which has 2 GB of space. As a best practice, delete these files to ensure enough space exists in intflash. New debug files do not overwrite old debug files. You must remove the file; otherwise, enough free space may not exist in the intflash to store the core dump if the switch fails or enough space may not exist for you to transfer a new release to the intflash of the switch to upgrade your switch.
The debug-file remove command can delete the following types of files:
core
archive
PMEM
dmalloc
flrec
wd_stats
If you want to delete a specific file, you must use the remove command. For more information, see VOSS Command Line Interface Commands Reference.
The following example shows how you view all debug files for all slots, and then remove the debug files for slot 1.
Switch>show debug-file
Core Files
Directory: /intflash/coreFiles/1
1. File: core.logServer.20120611084204.1.tar
Created: Mon Jun 11 08:42:04 2012
2. File: core.trcServer.20120611084213.1.tar
Created: Mon Jun 11 08:42:13 2012
3. File: core.logServer.20120611164647.1.tar
Created: Mon Jun 11 16:46:48 2012
4. File: core.trcServer.20120611164652.1.tar
Created: Mon Jun 11 16:46:52 2012
5. File: core.dbgServer.20120611164700.1.tar
Created: Mon Jun 11 16:47:01 2012
6. File: core.logServer.20120611164740.1.tar
Created: Mon Jun 11 16:47:41 2012
Remote CP Directory: /intflash/coreFiles/2
1. File: core.coreManager.x.20120612085548.2.tar
Created: Tue Jun 12 08:55:49 2012
2. File: core.coreManager.x.20120612085602.2.tar
Created: Tue Jun 12 08:56:02 2012
3. File: core.coreManager.x.20120612085553.2.tar
Created: Tue Jun 12 08:55:56 2012
4. File: core.coreManager.x.20120612085558.2.tar
Created: Tue Jun 12 08:56:00 2012
Archive Files
Directory: /intflash/archive/1
1. File: archive.20120611083021.1.tar
Created: Mon Jun 11 08:30:22 2012
2. File: archive.20120611163454.1.tar
Created: Mon Jun 11 16:34:54 2012
3. File: archive.20120611164354.1.tar
Created: Mon Jun 11 16:43:55 2012
4. File: archive.20120611164507.1.tar
Created: Mon Jun 11 16:45:08 2012
Remote CP Directory: /intflash//archive/2
1. File: archive.20120611163507.2.tar
Created: Mon Jun 11 16:35:08 2012
2. File: archive.20120611164408.2.tar
Created: Mon Jun 11 16:44:09 2012
3. File: archive.20120611164521.2.tar
Created: Mon Jun 11 16:45:21 2012
Directory: /intflash/archive/4
1. File: archive.20120611163515.4.tar
Created: Mon Jun 11 16:35:18 2012
2. File: archive.20120611164416.4.tar
Created: Mon Jun 11 16:44:20 2012
3. File: archive.20120611164529.4.tar
Created: Mon Jun 11 16:45:33 2012
Directory: /intflash/archive/SF4
1. File: archive.20120611163536.SF4.tar
Created: Mon Jun 11 16:35:40 2012
2. File: archive.20120611164436.SF4.tar
Created: Mon Jun 11 16:44:39 2012
3. File: archive.20120611164549.SF4.tar
Created: Mon Jun 11 16:45:53 2012
PMEM Files
Directory: /intflash/PMEM/4
1. File: pmem.20120607194023.4.bin.gz
Created: Thu Jun 7 19:40:23 2012
DMalloc Files
Flrec Files
WdStats Files
Directory: /intflash/wd_stats/4
1. File: wd_stats.log.backup
Created: Mon Jun 11 09:25:07 2012
Switch>debug-file remove 1
Core Files
Archive Files
PMEM Files
DMalloc Files
Flrec Files
WdStats Files
The following example shows how to view only core files on the switch.
Switch#show core-files
Core Files
1. File: core.1353113115.lifecycle.CP.1.gz
Created: Fri Nov 16 19:45:15 2012
2. File: core.cbcp-main.x.20121114043335.1.tar
Created: Wed Nov 14 04:35:36 2012
3. File: core.cbcp-main.x.20121114045202.1.tar
Created: Wed Nov 14 04:54:03 2012
4. File: core.cbcp-main.x.20121114050825.1.tar
Created: Wed Nov 14 05:10:26 2012
5. File: core.cbcp-main.x.20121114122506.1.tar
Created: Wed Nov 14 12:27:07 2012
6. File: core.1353336274.lifecycle.CP.1.gz
Created: Mon Nov 19 09:44:34 2012
7. File: core.1353319337.lifecycle.CP.1.gz
Created: Mon Nov 19 05:02:17 2012
8. File: core.cbcp-main.x.20130122182946.1.tar
Created: Tue Jan 22 18:32:08 2013
9. File: core.cbcp-main.x.20130220143809.1.tar
Created: Wed Feb 20 14:38:10 2013
10. File: core.cbcp-main.x.20130225155025.1.tar
Created: Mon Feb 25 15:50:25 2013
11. File: core.cbcp-main.x.20130225155407.1.tar
Created: Mon Feb 25 15:54:07 2013
The following table defines parameters for the show core-files command.
Variable |
Value |
{slot[-slot][,...]} |
Displays the core files for the slot that you select. |
The following table defines parameters for the show debug-file command.
Variable |
Value |
all |
Displays all types of debug files |
Displays debug files for the slot that you select. If you do not select a slot number, the device displays all types of the archived debug files present in a slot by slot basis. If you select a slot number, the device only displays archived files for the slot you select. |
The following table defines parameters for the debug-file remove command.
Variable |
Value |
all |
Removes all types of debug files in all slots. If you use the option all with the remove debug-file command, then the device deletes all types of debug files, including the latest debug files. |
{slot[-slot][,...]} Note:
Exception: only supported on VSP 8600 Series. |
Removes debug files for the slot that you select. When you clear archived files, if you do not select a slot number, the device deletes all types of archived debug files except the latest file in each slot. Valid slots are 1–12, SF1–SF6, and all. |
