Use the following procedure to display the status of the EAP-based security.
Product Notice: auto-isid-offset functionality is not available on VSP 4450 Series, VSP 8600 Series, or XA1400 Series.
Switch:#enable
Switch:1#show eapol system
Eapol System
eap : disabled
Eapol Version : 3
non-eap-pwd-fmt : mac-addr
non-eap-pwd-fmt key : ******
non-eap-pwd-fmt padding : disabled
auto-isid-offset status : disabled
auto-isid-offset value : 1000
Switch:>enable
Switch:1#config terminal
Switch:1(config)#show eapol sessions eap verbose
Eap Oper Status Verbose
PORT MAC PAE VLAN PRI Flex-UNI I-SID VLAN:I-SID ACL ACEs RADIUS DYNAMIC
NUM STATUS ID Enable SOURCE SETTINGS
1/13 00:00:11:11:16:02 authenticated 111 1 false n/a DHCPSNOOP, DAI
1/13 00:00:11:11:16:03 authenticated 111 1 false n/a DHCPSNOOP
Switch:>enable
Switch:1(config)#show eapol sessions neap verbose
Non-Eap Oper Status Verbose
PORT MAC STATE VLAN PRI Flex-UNI I-SID NON-EAP VLAN:I-SID ACL ACEs RADIUS DYNAMIC
NUM ID Enable SOURCE AUTH SETTINGS
1/15 00:00:00:00:00:15 authenticated 1 0 false n/a radius IPSG, DHCPSNOOP, DAI, IGMPSNOOP
1/15 00:00:00:00:00:16 authenticated 1 0 false n/a radius BPDU, SLPPGUARD, WOL, AN-ADVERTISEMENTS:100F
Total Number of NEAP Sessions: 2
The following table defines parameters for the show eapol command.
Variable |
Value |
auth-stats [gigabitEthernet {slot/port[/sub-port] [-slot/port[/sub-port]] [,...]}] |
Displays the authentication statistics interface. Note:
auth-stats [gigabitEthernet {slot/port[/sub-port] [-slot/port[/sub-port]] [,...]}] is useful only for EAP supplicants. The command output changes only when the EAP supplicant tries to access the network. |
multihost non-eap-mac status [vlan <1-4059>] [{slot/port[/sub-port] [-slot/port[/sub-port]] [,...]}] Note:
Exception: This parameter applies to VSP 8600 Series only. |
Displays EAP multihost configuration. |
port {interface [gigabitEthernet {slot/port[/sub-port] [-slot/port[/sub-port]] [,...]}] | {slot/port[/sub-port] [-slot/port[/sub-port]] [,...]}} |
Specifies the ports to display. If no port is entered, all ports are displayed. |
session-stats interface [gigabitEthernet {slot/port[/sub-port] [-slot/port[/sub-port]] [,...]}] |
Displays the authentication session statistics interface. |
sessions {eap | neap} [vlan<1-4059>] [{slot/port[/sub-port] [-slot/port[/sub-port]] [,...]}] [verbose] Note:
Exception: This parameter does not apply to VSP 8600 Series or XA1400 Series. |
Displays EAP and non-EAP authentication sessions on the port. |
status interface [vlan <1-4059>] [gigabitEthernet {slot/port[/sub-port] [-slot/port[/sub-port]] [,...]}] Note:
Displays the port EAP operation statistics. |
summary port[{slot/port[/sub-port] [-slot/port[/sub-port]] [,...]}] |
Displays EAP and NEAP clients. |
system |
Displays EAP settings. |
