Perform the following procedure to display the chassis shortcut menu.
- In the Device Physical View, select the chassis.
- Right-click the chassis.
Chassis shortcut menu field descriptions
Use the data in the following table to use the Chassis shortcut menu.
Name |
Description |
Edit |
Edits chassis parameters. |
Graph |
Graphs chassis statistics. |
Refresh Status |
Refreshes the status of the chassis and MDAs. |
Refresh Port Tooltips |
Refreshes the port tooltip data of the system. The port tooltip data contains the following variables: Slot/Port, PortName, and PortOperSpeed. |
