IEEE standard |
Description |
802.1AB |
LLDP |
802.1ag |
Connectivity Fault Management |
802.1ah |
Provider Backbone Bridging |
802.1aq |
Shortest Path Bridging (SPB) |
802.1AX |
Link Aggregation |
802.1D |
MAC Bridges |
P802.1p |
Traffic Class Expediting and Dynamic Multicast Filtering |
802.1Q |
Virtual LANs |
802.1s |
Multiple Spanning Trees |
802.1t |
802.1D Technical & Editorial Corrections |
802.1w |
Rapid Spanning Tree Protocol (RSTP) |
802.1X-2010 |
Port-based Network Access Control (NAC) |
802.3 CSMA/CD Ethernet ISO/IEC 8802 |
International Organization for Standardization (ISO) /International Eletrotechnical Commission (IEC) 8802-3 |
802.3ab |
1000 Mbps Operation, implemented as 1000BASE-T Copper |
802.1AE |
MAC Security Note: 5420 Series does not currently support MACsec in
software.
802.3ae |
10 Gbps Operation, implemented as 10GBASE-X SFP+ |
802.3af 802.3at 802.3bt (Type 3 and Type 4) |
Power over Ethernet (PoE) |
802.3az |
Energy Efficient Ethernet (EEE) |
802.3ba |
40 Gbps and 100 Gbps Operation, implemented as 40GBASE-QSFP+ and 100GBASE-QSFP28 |
802.3x |
Full Duplex & Flow Control |
802.3z |
1000 Mbps Operation, implemented as 1000BASE-X SFP |
ANSI/TIA-1057 |
LLDP-MED |
