DEMO FEATURE - Two-Factor Authentication–X.509v3 Certificates for SSH is a demonstration feature on some products. Demonstration features are provided for testing purposes. Demonstration features are for lab use only and are not for use in a production environment. For more information on feature support, see VOSS Feature Support Matrix.
The following table defines parameters for the ssh x509v3-auth command.
| Variable | Value |
<none|oscp> |
Specifies the X.509 V3 authentication revocation check method. The default is OCSP.
x509v3-auth is available for demonstration purposes on some products. For more information, see VOSS Feature Support Matrix. |
overwrite|strip-domain|use-domain WORD<1-254> |
Specifies the X.509 V3 username configuration. The default is disabled.
