Verify that SSH services are enabled on the switch and display SSH configuration information to ensure that the SSH parameters are properly configured.
Display global system SSH information:
Switch:1>show ssh global
Total Active Sessions : 0
version : v2only
port : 22
max-sessions : 4
timeout : 60
action rsa-host key : rsa-hostkeysize 2048
action dsa-host key : dsa-hostkeysize 1024
rsa-auth : false
dsa-auth : true
pass-auth : true
keyboard-interactive-auth : false
sftp enable : true
enable : true
authentication-type : aead-aes-128-gcm-ssh aead-aes-256-gcm-ssh hmac-sha1 hmac-sha2-256
encryption-type : 3des-cbc aead-aes-128-gcm-ssh aead-aes-256-gcm-ssh aes128-cbc aes128-ctr
aes192-cbc aes192-ctr aes256-cbc aes256-ctr blowfish-cbc rijndael128-cbc
rijndael192-cbc
key-exchange-method : diffie-hellman-group1-sha1 diffie-hellman-group14-sha1
The following table defines parameters for the show ssh command.
Variable |
Value |
global |
Display global system SSH information. |
session |
Display the current session SSH information. |
