Configures, modifies or retrieves MPLS Bypass LSP information.
URI | Description |
<base_URI>/config/running/router/mpls/bypass-lsp | Configures, modifies or retrieves MPLS Bypass LSP information. |
GET URIs | Descriptions |
<base_URI>/config/running/router/mpls/bypass-lsp/{bypass-lsp-name} | Configures, modifies or retrieves MPLS Bypass LSP information. |
<base_URI>/config/running/router/mpls/bypass-lsp/{bypass-lsp-name}/to | Retrieves LSP destination address. |
<base_URI>/config/running/router/mpls/bypass-lsp/{bypass-lsp-name}/from | Retrieves LSP source address. |
<base_URI>/config/running/router/mpls/bypass-lsp/{bypass-lsp-name}/tie-breaking | Retrieves the tie breaking mode configuration. |
<base_URI>/config/running/router/mpls/bypass-lsp/{bypass-lsp-name}/adaptive | Retrieves LSP adaptive configuration. |
<base_URI>/config/running/router/mpls/bypass-lsp/{bypass-lsp-name}/reoptimize-timer | Retrieves Reoptimization timer configuration. |
<base_URI>/config/running/router/mpls/bypass-lsp/{bypass-lsp-name}/commit | Retrieves changes to adaptive LSP configuration. |
<base_URI>/config/running/router/mpls/bypass-lsp/{bypass-lsp-name}/record | Retrieves the recording path routes configuration. |
<base_URI>/config/running/router/mpls/bypass-lsp/{bypass-lsp-name}/cos | Retrieves class of service. |
<base_URI>/config/running/router/mpls/bypass-lsp/{bypass-lsp-name}/hop-limit | Displays the imit of hops the LSP can traverse. |
<base_URI>/config/running/router/mpls/bypass-lsp/{bypass-lsp-name}/cspf-computation-mode | Displays cspf-computation-mode. |
<base_URI>/config/running/router/mpls/bypass-lsp/{bypass-lsp-name}/traffic-engineering | Displays traffic engineering details. |
<base_URI>/config/running/router/mpls/bypass-lsp/{bypass-lsp-name}/traffic-engineering/mean-rate | Retrieves the mean rate in kbps. Range is 0-2147483647. |
<base_URI>/config/running/router/mpls/bypass-lsp/{bypass-lsp-name}/traffic-engineering/max-rate | Retrieves the max-rate in kbps. Range is 0-2147483647. |
<base_URI>/config/running/router/mpls/bypass-lsp/{bypass-lsp-name}/traffic-engineering/max-burst | Retrieves the max-burst in bytes. Range is 0-2147483647. |
<base_URI>/config/running/router/mpls/bypass-lsp/{bypass-lsp-name}/priority | Displays priority |
<base_URI>/config/running/router/mpls/bypass-lsp/{bypass-lsp-name}/priority/lsp-hold-priority | Displays LSP-hold priority. Range is 0 to 7. Deafult is 0. |
<base_URI>/config/running/router/mpls/bypass-lsp/{bypass-lsp-name}/exclude-any | Exclude any of the administrative groups. |
<base_URI>/config/running/router/mpls/bypass-lsp/{bypass-lsp-name}/include-any | Include any of the administrative groups |
<base_URI>/config/running/router/mpls/bypass-lsp/{bypass-lsp-name}/include-all | Include all of the administrative groups |
<base_URI>/config/running/router/mpls/bypass-lsp/{bypass-lsp-name}/exclude-interface/{bypass-exclude-interface-type},{bypass-exclude-interface-name} | Displays exclude-interface status (true / false). |
<base_URI>/config/running/router/mpls/bypass-lsp/{bypass-lsp-name}/primary-path | Displays primary explicit path. |
<base_URI>/config/running/router/mpls/bypass-lsp/{bypass-lsp-name}/enable | Enables a bypass lsp. |
POST URIs | Payload | Description |
<base_URI>/config/running/router/mpls | <bypass-lsp><bypass-lsp-name>{string}</bypass-lsp-name></bypass-lsp> | Creates bypass LSP configuration. |
<base_URI>/config/running/router/mpls/bypass-lsp/{bypass-lsp-name} | <exclude-interface><bypass-exclude-interface-type>{mpls-interface-type}</bypass-exclude-interface-type><bypass-exclude-interface-name>{interface-type}</bypass-exclude-interface-name></exclude-interface> | Configures a bypass LSP. |
PATCH URIs | Payload | Description |
<base_URI>/config/running/router/mpls/bypass-lsp/{bypass-lsp-name} | <bypass-lsp><to>{inet:ipv4-address}</to></bypass-lsp> | Configures LSP destination address. |
<base_URI>/config/running/router/mpls/bypass-lsp/{bypass-lsp-name} | <bypass-lsp><from>{inet:ipv4-address}</from></bypass-lsp> | Configures LSP source address. |
<base_URI>/config/running/router/mpls/bypass-lsp/{bypass-lsp-name} | <bypass-lsp><tie-breaking>{tie-breaking}</tie-breaking></bypass-lsp> | Configures the tie breaking mode. |
<base_URI>/config/running/router/mpls/bypass-lsp/{bypass-lsp-name} | <bypass-lsp><adaptive>true</adaptive></bypass-lsp> | Modifies the LSP adaptive configuration. |
<base_URI>/config/running/router/mpls/bypass-lsp/{bypass-lsp-name} | <bypass-lsp><reoptimize-timer>{uint32}</reoptimize-timer></bypass-lsp> | Modifies eeoptimization timer configuration. |
<base_URI>/config/running/router/mpls/bypass-lsp/{bypass-lsp-name} | <bypass-lsp><commit>true</commit></bypass-lsp> | Commit the changes to adaptive LSP. |
<base_URI>/config/running/router/mpls/bypass-lsp/{bypass-lsp-name} | <bypass-lsp><record>{enable-disable}</record></bypass-lsp> | Enablesdisables recording path routes. |
<base_URI>/config/running/router/mpls/bypass-lsp/{bypass-lsp-name} | <bypass-lsp><cos>{uint32}</cos></bypass-lsp> | Updates class of service. |
<base_URI>/config/running/router/mpls/bypass-lsp/{bypass-lsp-name} | <bypass-lsp><hop-limit>{uint16}</hop-limit></bypass-lsp> | Updates the limit of hops which the LSP can traverse. |
<base_URI>/config/running/router/mpls/bypass-lsp/{bypass-lsp-name} | <bypass-lsp><cspf-computation-mode>{cspf-computation-mode}</cspf-computation-mode></bypass-lsp> | Updates cspf-computation-mode. |
<base_URI>/config/running/router/mpls/bypass-lsp/{bypass-lsp-name}//traffic-engineering | <traffic-engineering><mean-rate>{uint32}</mean-rate></traffic-engineering> | Updates mean rate in kbps. Range is 0-2147483647. |
<base_URI>/config/running/router/mpls/bypass-lsp/{bypass-lsp-name}/traffic-engineering | <traffic-engineering><max-rate>{uint32}</max-rate></traffic-engineering> | Updates max rate in kbps. Range is 0-2147483647. |
<base_URI>/config/running/router/mpls/bypass-lsp/{bypass-lsp-name}/traffic-engineering | <traffic-engineering><max-burst>{uint32}</max-burst></traffic-engineering> | Updates Max-burst in bytes. Range is 0-2147483647. |
<base_URI>/config/running/router/mpls/bypass-lsp/{bypass-lsp-name}/priority | <priority><lsp-setup-priority>{uint32}</lsp-setup-priority><lsp-hold-priority>{uint32}</lsp-hold-priority></priority> | Updates the lsp setup priority to include all ofthe administrative groups. |
<base_URI>/config/running/router/mpls/bypass-lsp/{bypass-lsp-name} | <bypass-lsp><exclude-any>{string}</exclude-any></bypass-lsp> | Excludes any of the administrative groups. |
<base_URI>/config/running/router/mpls/bypass-lsp/{bypass-lsp-name} | <bypass-lsp><include-any>{string}</include-any></bypass-lsp> | Includes any of the administrative groups |
<base_URI>/config/running/router/mpls/bypass-lsp/{bypass-lsp-name} | <bypass-lsp><include-all>{string}</include-all></bypass-lsp> | Includes all of the administrative groups |
<base_URI>/config/running/router/mpls/bypass-lsp/{bypass-lsp-name} | <bypass-lsp><primary-path>{string}</primary-path></bypass-lsp> | Updates a primary explicit path. |
<base_URI>/config/running/router/mpls/bypass-lsp/{bypass-lsp-name} | <bypass-lsp><enable>true</enable></bypass-lsp> | Enables a bypass LSP. |
PUT URIs | PAYLOAD | Descriptions |
<base_URI>/config/running/router/mpls/bypass-lsp/{bypass-lsp-name}/to | <to>{inet:ipv4-address}</to> | Configures bypass LSP destination address. |
<base_URI>/config/running/router/mpls/bypass-lsp/{bypass-lsp-name}/from | <from>{inet:ipv4-address}</from> | Configures bypass LSP source address. |
<base_URI>/config/running/router/mpls/bypass-lsp/{bypass-lsp-name}/tie-breaking | <tie-breaking>{tie-breaking}</tie-breaking> | Updates the tie breaking mode. |
<base_URI>/config/running/router/mpls/bypass-lsp/{bypass-lsp-name}/adaptive | <adaptive>true</adaptive> | Configures bypass LSP adaptive configuration. |
<base_URI>/config/running/router/mpls/bypass-lsp/{bypass-lsp-name}/reoptimize-timer | <reoptimize-timer>{uint32}</reoptimize-timer> | Configures reoptimization timer. |
<base_URI>/config/running/router/mpls/bypass-lsp/{bypass-lsp-name}/commit | <commit>true</commit> | Commit the changes to adaptive LSP. |
<base_URI>/config/running/router/mpls/bypass-lsp/{bypass-lsp-name}/record | <record>{enable-disable}</record> | Enable/disable recording path routes. |
<base_URI>/config/running/router/mpls/bypass-lsp/{bypass-lsp-name}/cos | <cos>{uint32}</cos> | Configure class of service. |
<base_URI>/config/running/router/mpls/bypass-lsp/{bypass-lsp-name}/hop-limit | <hop-limit>{uint16}</hop-limit> | Configures limit of hops the LSP can traverse. |
<base_URI>/config/running/router/mpls/bypass-lsp/{bypass-lsp-name}/cspf-computation-mode | <cspf-computation-mode>{cspf-computation-mode}</cspf-computation-mode> | Specify cspf-computation-mode. |
<base_URI>/config/running/router/mpls/bypass-lsp/{bypass-lsp-name}/traffic-engineering/mean-rate | <mean-rate>{uint32}</mean-rate> | Sets Mean rate in kbps. Range is 0-2147483647. |
<base_URI>/config/running/router/mpls/bypass-lsp/{bypass-lsp-name}/traffic-engineering/max-rate | <max-rate>{uint32}</max-rate> | Sets Max-rate in kbps. Range is 0-2147483647. |
<base_URI>/config/running/router/mpls/bypass-lsp/{bypass-lsp-name}/traffic-engineering/max-burst | <max-burst>{uint32}</max-burst> | Sets Max-burst-rate in kbps. Range is 0-2147483647. |
<base_URI>/config/running/router/mpls/bypass-lsp/{bypass-lsp-name}/priority/lsp-hold-priority | <priority><lsp-setup-priority>{uint32}</lsp-setup-priority><lsp-hold-priority>{uint32}</lsp-hold-priority></priority> | Sets lsp hold priority. |
<base_URI>/config/running/router/mpls/bypass-lsp/{bypass-lsp-name}/exclude-any | <exclude-any>{string}</exclude-any> | Excludes any of the administrative groups. |
<base_URI>/config/running/router/mpls/bypass-lsp/{bypass-lsp-name}/include-any | <include-any>{string}</include-any> | Includes any of the administrative groups |
<base_URI>/config/running/router/mpls/bypass-lsp/{bypass-lsp-name}/include-all | <include-all>{string}</include-all> | Includes all of the administrative groups |
<base_URI>/config/running/router/mpls/bypass-lsp/{bypass-lsp-name}/primary-path | <primary-path>{string}</primary-path> | Updates a primary explicit path. |
<base_URI>/config/running/router/mpls/bypass-lsp/{bypass-lsp-name}/enable | <enable>true</enable> | Enables a bypass LSP. |
DELETE URIs |
GET, POST, PUT, PATCH, DELETE, OPTIONS, and HEAD operations are supported.
The following example uses the GET option to retrieve the configuration details.
http://host:80/rest/config/running/router/mpls/bypass-lsp/bypass1
None
<bypass-lsp xmlns="urn:brocade.com:mgmt:brocade-mpls" xmlns:y="http://brocade.com/ns/rest" y:self="/rest/config/running/router/mpls/bypass-lsp/bypass1"> <bypass-lsp-name>bypass1</bypass-lsp-name> <traffic-engineering y:self="/rest/config/running/router/mpls/bypass-lsp/bypass1/traffic-engineering"> </traffic-engineering> <priority y:self="/rest/config/running/router/mpls/bypass-lsp/bypass1/priority"> </priority> </bypass-lsp>
The following example uses the POST option to configure a bypass LSP, "bypass1".
<bypass-lsp><bypass-lsp-name>bypass1</bypass-lsp-name></bypass-lsp>
None.
The following example uses the DELETE option to remove a configured bypass LSP, "bypass1".
None
None
