Configures, modifies, or retrieves IP Dynamic Host Configuration Protocol (DHCP).
URI | Description |
<base_URI>/config/running/ip/dhcp/relay | Configures DHCP relay. |
GET URIs | Description |
<base_URI>/config/running/ip | Configure Internet Protocol (IP). |
<base_URI>/config/running/ip/dhcp | Configures Dynamic Host Configuration Protocol (DHCP). |
<base_URI>/config/running/ip/dhcp/relay/information/option | Configures DHCP relay. |
POST URIs | Payload | Description |
<base_URI>/config/running/ip/dhcp/relay/information | <option> </option> | Configures DHCP relay option. |
PATCH URIs | Payload | Description |
PUT URIs | Payload | Description |
DELETE URIs |
GET, POST, PUT, PATCH, DELETE, OPTIONS, and HEAD operations are supported.
The following example uses the GET option to retrieve the configuration details.
http://host:80/rest/config/running/ip
None
<dhcp xmlns="urn:brocade.com:mgmt:brocade-dhcp" xmlns:y="http://brocade.com/ns/rest" y:self="/rest/config/running/ip/dhcp"> <relay y:self="/rest/config/running/ip/dhcp/relay"> <information y:self="/rest/config/running/ip/dhcp/relay/information"> <option>true</option> </information> </relay> </dhcp>
The following example uses the POST option to configure IP DHCP relay option.
http://host:80/rest/config/running/ip/dhcp/relay/information
None
The following example uses the DELETE option to remove IP DHCP relay option.
None
None
