Configures topology VLAN group for L2 protocols.
| URI | Description |
| <base_URI>/config/running/topology-group | Configures topology vlan group for L2 protocols. |
| GET URIa | Description |
| <base_URI>/config/running/topology-group | Retrieves topology group configuration details. |
| <base_URI>/config/running/topology-group/{group-id} | Retrieves information for a particular topology group. |
| <base_URI>/config/running/topology-group/{group-id}/master-vlan | Retrieves information about master VLAN. |
| <base_URI>/config/running/topology-group/{group-id}/member-vlan | Retrieves information about member VLAN. |
| POST URIs | Payload | Description |
| <base_URI>/config/running/topology-group | <topology-group><topology-group-id>(unit32)</topology-group-id></topology-group> | Configures topology group. |
| PATCH URIs | Payload | Description |
| <base_URI>/config/running/topology-group/{group-id}/master-vlan | <master-vlan>(unit32)</master-vlan> | Configures master VLAN. |
| <base_URI>/config/running/topology-group/{group-id}/member-vlan | <member-vlan><add>(unit32)</add></member-vlan> | Adds member VLAN. |
| <base_URI>/config/running/topology-group/{group-id}/member-vlan | <member-vlan><remove>(unit32)</remove></member-vlan> | Removes member VLAN. |
| <base_URI>/config/running/topology-group/{group-id}/member-vlan/remove | <remove>(unit32)</remove> | Removes member VLAN. |
| PUT URIs | Payload | Description |
| <base_URI>/config/running/topology-group/{group-id}/member-vlan/add | <add>(unit32)</add> | Removes member VLAN. |
| DELETE URIs |
| <base_URI>/config/running/topology-group/{group-id}/member-vlan/add/(vlan-id) |
| <base_URI>/config/running/topology-group/{group-id}/member-vlan/remove/(vlan-id) |
GET, POST, PUT, PATCH, DELETE, OPTIONS, and HEAD operations are supported.
The following example uses the GET option to retrieve the configuration details.
http://host:80/rest/config/running/topology-group
<topology-group> <topology-group-id>1</topology-group-id> </topology-group>
None
The following example uses the DELETE option to remove Topology group master VLAN.
http://host:80/rest/config/running/topology-group/1/master-vlan
None
None
