Configures, modifies, or retrieves a delay-link-event.
URI | Description |
/rest/config/running/interface/(interface-type)/(interface-name)/delay-link-event | Configures a delay-link-event. Supported interface type: Ethernet. |
GET URIs | Description |
/rest/config/running/interface/(interface-type)/(interface-name)/delay-link-event/delay-link-event-type | Delay link up event. Supported interface type: Ethernet. |
PUT URIs | Payload | Description |
/rest/config/running/interface/(interface-type)/(interface-name)/delay-link-event/delay-link-event-entry | <delay-link-event-entry>15</delay-link-event-entry> | Number of delay link event entry. Supported interface type: Ethernet. |
DELETE URIs |
Supported interface type: Ethernet only.
GET, POST, PUT, PATCH, DELETE, OPTIONS, and HEAD operations are supported.
The following example uses the GET option to retrieve the configuration details.
http://host:80/rest/config/running/interface/ethernet/%221/1%22/delay-link-event
None
<delay-link-event xmlns="urn:brocade.com:mgmt:brocade-dle" xmlns:y="http://brocade.com/ns/rest" y:self="/rest/config/running/interface/Ethernet/%221/1%22/delay-link-event"> <delay-link-event-entry>3</delay-link-event-entry> <delay-link-event-type>both</delay-link-event-type> </delay-link-event>
The following example uses PUT operation to update the delay time.
http://host:80/rest/config/running/interface/ethernet/%221/1%22/delay-link-event/delay-link-event-entry
None
The following example uses DELETE operation to remove the delay-link-event configuration.
None
None
