Displays information on the LDP session.
URI | Description |
<base-URI>/operational-state/mpls-state/ldp/ldp-session | Displays information on the LDP session. |
<base_URI>operational-state/mpls-state/ldp/ldp-session/(ip-address) | Displays the LDP session IP address. |
<base_URI>/operational-state/mpls-state/ldp/ldp-session/ip/session-ldp-stats | Displays LDP session status. |
Only GET operation is supported. Use of the Resource-Depth request header is recommended.
http://host:80/rest/operational-state/mpls-state/ldp/ldp-session
None
<ldp-session xmlns="urn:brocade.com:mgmt:brocade-mpls-operational" xmlns:y="http://brocade.com/ns/rest" y:self="/rest/operational-state/mpls-state/ldp/ldp-session/4.4.3.2:0"> <peer-ldp-id>4.4.3.2:0</peer-ldp-id> <peer-lblspc-id>""</peer-lblspc-id> <state>Operational</state> <adjacency>Targeted</adjacency> <role>Passive</role> <max-hold>36</max-hold> <time-left>31</time-left> <session-status>Up</session-status> <local-ldp-id>1.2.3.4:0</local-ldp-id> <local-lblspc-id>""</local-lblspc-id> <next-keepalive>3</next-keepalive> <entity-index>2</entity-index> <targeted-adj-added>Yes</targeted-adj-added> <is-retry>false</is-retry> <next-retry>0</next-retry> <keepalive-interval>6000</keepalive-interval> <local-keepalive-timeout>36</local-keepalive-timeout> <peer-proposed-keepalive-timeout>36</peer-proposed-keepalive-timeout> <session-up-time>"22 hr 44 min 19 sec "</session-up-time> <tcp-conn-local>1.2.3.4:646</tcp-conn-local> <tcp-conn-remote>4.4.3.2:13603</tcp-conn-remote> <tcp-state>ESTABLISHED</tcp-state> <num-fecs-received-from-peer>251</num-fecs-received-from-peer> <num-fecs-installed-from-peer>250</num-fecs-installed-from-peer> <is-fecs-pending-uninstall>false</is-fecs-pending-uninstall> <num-fecs-filtered-out>0</num-fecs-filtered-out> <num-fecs-filtered-in>0</num-fecs-filtered-in> <filter-prefix-list-exists>false</filter-prefix-list-exists> <is-only-gr-valid>false</is-only-gr-valid> <gr-enabled>false</gr-enabled> <peer-reconnect-time>0</peer-reconnect-time> <peer-recovery-time>0</peer-recovery-time> <reconnect-time-in-use>0</reconnect-time-in-use> <reconnect-time-remaining>0</reconnect-time-remaining> <recovery-time-in-use>0</recovery-time-in-use> <recovery-time-remaining>0</recovery-time-remaining> <local-eol-unrecognized-notification>false</local-eol-unrecognized-notification> <remote-eol-unrecognized-notification>false</remote-eol-unrecognized-notification> <does-session-support-eol>false</does-session-support-eol> <local-state>true</local-state> <remote-state>false</remote-state> <eol-notification-time>0</eol-notification-time> <eol-notification-time-remaining>0</eol-notification-time-remaining> <eol-tx-label-silence-time>0</eol-tx-label-silence-time> <eol-tx-label-silence-time-remaining>0</eol-tx-label-silence-time-remaining> <eol-rx-label-silence-time>1000</eol-rx-label-silence-time> <eol-rx-label-silence-time-remaining>0</eol-rx-label-silence-time-remaining> <filtered>enum=0</filtered> <interfaces>(targeted)</interfaces> <addresses>4.4.3.2 34.34.34.2 45.45.45.1</addresses> <session-ldp-stats y:self="/rest/operational-state/mpls-state/ldp/ldp-session/4.4.3.2:0/session-ldp-stats"> <ldp-protocol-errors-instance-total y:self="/rest/operational-state/mpls-state/ldp/ldp-session/4.4.3.2:0/session-ldp-stats/ ldp-protocol-errors-instance-total"> </ldp-protocol-errors-instance-total> <ldp-protocol-stats-instance-total y:self="/rest/operational-state/mpls-state/ldp/ldp-session/4.4.3.2:0/session-ldp-stats/ ldp-protocol-stats-instance-total"> </ldp-protocol-stats-instance-total> </session-ldp-stats> </ldp-session>
