hardware
Configures, modifies, or retrieves the hardware management configuration.
Resource URIs
URI Description
<base_URI>/config/running/hardware Hardware management configuration
<base_URI>/config/running/hardware/connector Connector. Refer to hardware/connector for information.
<base_URI>/config/running/hardware/port-group Port group. Refer to hardware/port-group for information.
GET URIs Description
/rest/config/running/hardware Hardware Management configuration
/rest/config/running/hardware/connector/(connectorName) Configures a connector with the specified name
/rest/config/running/hardware/connector/(connectorName)/breakout Configures a breakout connector
/rest/config/running/hardware/connector/(connectorName)/breakout/mode Configures connector mode
/rest/config/running/hardware/port-group/(portGroupName) Configures a port-group in a specified name
/rest/config/running/hardware/port-group/(portGroupName)/mode Configures port-group mode
POST URIs Payload Description
/rest/config/running <hardware /> Hardware management configuration
/rest/config/running/hardware <connector><name>(connectorName)</name></connector> Configures a connector
/rest/config/running/hardware/connector/(connectorName) <breakout /> Configures a breakout connector
/rest/config/running/hardware <port-group><name>(portGroupName)</name></port-group> Configures a port-group
PATCH URIs Payload Description
/rest/config/running/hardware/connector/(connectorName)/breakout <breakout><mode>(mode)</mode></breakout> Configures a breakout connector
/rest/config/running/hardware/port-group/(portGroupName) <port-group><mode>(mode)</mode></port-group> Configures a port-group in a specified name
DELETE URIs Payload Description
Parameters
connector
Configures a connector.
port-group
Configures a port group.
Usage Guidelines
GET, POST, PUT, PATCH, OPTIONS, and HEAD operations are supported.
URI
The following example uses the GET option to retrieve the configuration details.
http://host:80/rest/config/running/hardware
None
<hardware xmlns="urn:brocade.com:mgmt:brocade-hardware" xmlns:y="http://brocade.com/ns/rest"
y:self="/rest/config/running/hardware">
  <profile y:self="/rest/config/running/hardware/profile">
    <tcam y:self="/rest/config/running/hardware/profile/tcam">
      <tcam_profiletype>default</tcam_profiletype>
    </tcam>
    <lag y:self="/rest/config/running/hardware/profile/lag">
      <lag_profiletype>default</lag_profiletype>
    </lag>
    <counters y:self="/rest/config/running/hardware/profile/counters">
      <counters_profiletype>default</counters_profiletype>
    </counters>
  </profile>
  <port-group y:self="/rest/config/running/hardware/port-group/%221/4%22">
    <name>1/4</name>
    <mode>100g</mode>
  </port-group>
</hardware>
