Configures, modifies, or retrieves the Open Shortest Path First (OSPF) version 3.
| URI | Description |
| <base_URI>/config/running/interface/{interface-type}/{interface-name}/ipv6/ospf/active | Configures PBR (IPv6).
					  Valid interface types: Ethernet, Ve, Loopback.  |
| GET URIs | Description |
| <base_URI>/config/running/interface/{interface-type}/{interface-name}/ipv6/ospf/area | Displays the OSPF router area id.
| <base_URI>/config/running/interface/{interface-type}/{interface-name}/ipv6/ospf/active | Sets a specific OSPFv3 interface to active.
| <base_URI>/config/running/interface/{interface-type}/{interface-name}/ipv6/ospf/passive | Sets a specific OSPFv3 interface to passive.
| <base_URI>/config/running/interface/{interface-type}/{interface-name}/ipv6/ospf/cost | Displays cost for a specific OSPFv3 interface.
| <base_URI>/config/running/interface/{interface-type}/{interface-name}/ipv6/ospf/instance | Displays the number of OSPFv3 instances running on an interface.
| <base_URI>/config/running/interface/{interface-type}/{interface-name}/ipv6/ospf/mtu-ignore | Displays whether maximum transmission unit (MTU) match checking is enabled or disabled.
| <base_URI>/config/running/interface/{interface-type}/{interface-name}/ipv6/ospf/network | Displays network type.
| <base_URI>/config/running/interface/{interface-type}/{interface-name}/ipv6/ospf/priority | Displays priority for designated router (DR) election and backup designated routers (BDRs) on the interface you are connected to.
| <base_URI>/config/running/interface/{interface-type}/{interface-name}/ipv6/ospf/suppress-linklsa | Displays whether link LSA advertisements are suppressed.
| <base_URI>/config/running/interface/{interface-type}/{interface-name}/ipv6/ospf/authentication | Displays authentication for the interface.
| <base_URI>/config/running/interface/{interface-type}/{interface-name}/ipv6/ospf/authentication/ipsec | Displays IPSEC authentication for the interface.
| <base_URI>/config/running/interface/{interface-type}/{interface-name}/ipv6/ospf/authentication/ipsec/key-add-remove-interval | Displays key add or remove interval in seconds.
| <base_URI>/config/running/interface/{interface-type}/{interface-name}/ipv6/ospf/hello-interval | Sets the length of time between the transmission of hello packets that an interface sends to neighbor routers.
| <base_URI>/config/running/interface/{interface-type}/{interface-name}/ipv6/ospf/dead-interval | Displays the time period for which a neighbor router waits for a hello packet from the device before declaring the router down.
| <base_URI>/config/running/interface/{interface-type}/{interface-name}/ipv6/ospf/hello-jitter | Displays the allowed jitter between HELLO packets.
| <base_URI>/config/running/interface/{interface-type}/{interface-name}/ipv6/ospf/retransmit-interval | Displays the retransmit interval.
| <base_URI>/config/running/interface/{interface-type}/{interface-name}/ipv6/ospf/transmit-delay | Displays transmit delay for link-update packets.
| PUT URIs | Payload | Description |
| <base_URI>/config/running/interface/{interface-type}/{interface-name}/ipv6/ospf/active | <active>{enumeration}</active> | Sets a specific OSPFv3 interface to active.
| <base_URI>/config/running/interface/{interface-type}/{interface-name}/ipv6/ospf/passive | <passive>{enumeration}</passive> | Sets a specific OSPFv3 interface to passive.
| <base_URI>/config/running/interface/{interface-type}/{interface-name}/ipv6/ospf/cost | <cost>{uint32}</cost> | Configures cost for a specific OSPFv3 interface.
| <base_URI>/config/running/interface/{interface-type}/{interface-name}/ipv6/ospf/instance | <instance>{uint32}</instance> | Specifies the number of OSPFv3 instances running on an interface.
| <base_URI>/config/running/interface/{interface-type}/{interface-name}/ipv6/ospf/mtu-ignore | <mtu-ignore>{enumeration}</mtu-ignore> | Enables or disables maximum transmission unit (MTU) match checking.
| <base_URI>/config/running/interface/{interface-type}/{interface-name}/ipv6/ospf/network | <network>{enumeration}</network> | Configures network type.
| <base_URI>/config/running/interface/{interface-type}/{interface-name}/ipv6/ospf/priority | <priority>{uint32}</priority> | Configures priority for designated router (DR) election and backup designated routers (BDRs) on the interface you are connected to.
| <base_URI>/config/running/interface/{interface-type}/{interface-name}/ipv6/ospf/suppress-linklsa | <suppress-linklsa>{enumeration}</suppress-linklsa> | Suppresses link LSA advertisements.
| <base_URI>/config/running/interface/{interface-type}/{interface-name}/ipv6/ospf/authentication/ipsec/key-add-remove-interval | <key-add-remove-interval>{common-def:time-interval-sec}</key-add-remove-interval> | Key add or remove interval in seconds.
| <base_URI>/config/running/interface/{interface-type}/{interface-name}/ipv6/ospf/hello-interval | <hello-interval>{common-def:time-interval-sec}</hello-interval> | Sets the length of time between the transmission of hello packets that an interface sends to neighbor routers.
| <base_URI>/config/running/interface/{interface-type}/{interface-name}/ipv6/ospf/dead-interval | <dead-interval>{common-def:time-interval-sec}</dead-interval> | Specifies the time period for which a neighbor router waits for a hello packet from the device before declaring the router down.
| <base_URI>/config/running/interface/{interface-type}/{interface-name}/ipv6/ospf/hello-jitter | <hello-jitter>{uint32}</hello-jitter> | Sets the allowed jitter between HELLO packets.
| <base_URI>/config/running/interface/{interface-type}/{interface-name}/ipv6/ospf/retransmit-interval | <retransmit-interval>{common-def:time-interval-sec}</retransmit-interval> | Configures the retransmit interval. The retransmit interval is the time between Link-State Advertisement (LSA) retransmissions to adjacent routers for a given interface.
| <base_URI>/config/running/interface/{interface-type}/{interface-name}/ipv6/ospf/transmit-delay | <transmit-delay>{common-def:time-interval-sec}</transmit-delay> | Configures transmit delay for link-update packets. The transmit delay is the estimated time required for OSPFv3 to send linkstate update packets on the interface to which you are connected.
| PATCH URIs | Payload | Description |
| <base_URI>/config/running/interface/{interface-type}/{name}/ipv6/ospf/authentication/ipsec | <authentication><spi>{spi-value-type}</spi><ah>{algorithm-type-ah}</ah><disable>{enumeration}</disable></authentication> | Security Parameter Index specifying the authentication algorithm to use.
| <base_URI>/config/running/interface/{interface-type}/{name}/ipv6/ospf/authentication/ipsec | <authentication><spi>{spi-value-type}</spi><no-encrypt>{enumeration}</no-encrypt><disable>{enumeration}</disable></authentication> | Security Parameter Index without encrypting the key.
| <base_URI>/config/running/interface/{interface-type}/{name}/ipv6/ospf/authentication/ipsec | <authentication><spi>{spi-value-type}</spi><key>{ipsec-authentication-hexkey-string}</key><disable>{enumeration}</disable></authentication> | Security Parameter Index with Key used for ah.
| <base_URI>/config/running/interface/{interface-type}/{name}/ipv6/ospf/authentication/ipsec | <authentication><spi>{spi-value-type}</spi><esp>{algorithm-type-esp}</esp><disable>{enumeration}</disable></authentication> | Security Parameter Index specifying Encapsulating Security Payload (ESP).
| <base_URI>/config/running/interface/{interface-type}/{name}/ipv6/ospf/authentication/ipsec | <authentication><spi>{spi-value-type}</spi><esp-no-encrypt>{enumeration}</esp-no-encrypt><disable>{enumeration}</disable></authentication> | Security Parameter Index without encrypting the key.
| <base_URI>/config/running/interface/{interface-type}/{name}/ipv6/ospf/authentication/ipsec | <authentication><spi>{spi-value-type}</spi><esp-key>{ipsec-authentication-hexkey-string}</esp-key><disable>{enumeration}</disable></authentication> | Security Parameter Index with Hexadecimal key string for ESP.
| <base_URI>/config/running/interface/{interface-type}/{name}/ipv6/ospf/authentication/ipsec | <authentication><spi>{spi-value-type}</spi><esp-auth>{algorithm-type-ah}</esp-auth><disable>{enumeration}</disable></authentication> | Security Parameter Index using Authentication Algorithm.
| <base_URI>/config/running/interface/{interface-type}/{name}/ipv6/ospf/authentication/ipsec | <authentication><spi>{spi-value-type}</spi><key>{ipsec-authentication-hexkey-string}</key><disable>{enumeration}</disable></authentication> | Security Parameter Index with Hexadecimal key string for authentication algorithm.
| <base_URI>/config/running/interface/{interface-type}/{name}/ipv6/ospf/authentication/ipsec | <ipsec><key-add-remove-interval>{common-def:time-interval-sec}</key-add-remove-interval></ipsec> | Key add or remove interval in seconds.
GET, PUT, PATCH, DELETE, OPTIONS, and HEAD operations are supported.
The following is an example of the PUT operation to configure a specific OSPFv3 interface to active.
http://host:80/rest/config/running/interface/Ethernet/%221/1%22/ipv6/ospf/active
<active>true</active>
None
