alias-config
Configures, modifies, or retrieves alias configuration.
Resource URIs
URI Description
<base_URI>/config/running/alias-config User and global alias
<base_URI>/config/running/alias-config/alias Global alias. Refer to alias-config/alias for information
<base_URI>/config/running/alias-config/user User alias. Refer to alias-config/user for information
Parameters
alias
Configures global alias.
user
Configures user alias mode.
Usage Guidelines
GET, POST, PUT, PATCH, DELETE, OPTIONS, and HEAD operations are supported.
The DELETE operation is supported only on alias and user URIs.
URI
The following example uses the GET option to retrieve the configuration details.
http://host:80/rest/config/running/alias-config
None
<alias-config xmlns="urn:brocade.com:mgmt:brocade-aaa" xmlns:y="http://brocade.com/ns/rest"
y:self="/rest/config/running/alias-config">
  <alias y:self="/rest/config/running/alias-config/alias/alias1"/>
  <user y:self="/rest/config/running/alias-config/user/user0"/>
</alias-config>
