Displays the status of dhcp snooping option and interface specific information like Circuit and Remote IDs
URI | Description |
<base_URI>/operational-state/dhcp-snooping-option-state | Displays the status of dhcp snooping option and interface specific information like Circuit and Remote IDs. |
Only GET operation is supported. Use of the Resource-Depth request header is recommended.
The following example shows the complete cURL command and server response for the
GET operation.
http://host:80/rest/operational-state/dhcp-snooping-option-state
curl -H "Accept: application/vnd.operational-state.resource+xml" -H "Resource-Depth: 6" -u "lab:Tester**" http://10.20.229.40:80/rest/operational-state/dhcp-snooping-option-state
<data xmlns="http://brocade.com/ns/rest" xmlns:y="http://brocade.com/ns/rest" y:self="/rest/operational-state"> <dhcp-snooping-option-state xmlns="urn:brocade.com:mgmt:brocade-dhcp-operational" y:self="/rest/operational-state/ dhcp-snooping-option-state"> <option82>false</option82> </dhcp-snooping-option-state> </data>
Release version | History |
18r.2.00 | This API call was introduced. |
