Configures, modifies, or retrieves Interface Loop Detection configuration.
URI | Description |
<base_URI>/config/running/interface/{interface-type}/{interface-name}/loop-detection | Configures, modifies, or retrieves Interface Loop Detection configuration details. |
GET URIs | Description |
<base_URI>/config/running/interface/{interface-type}/{interface-name}/loop-detection | Displays the interface-level Loop-Detection information. |
<base_URI>/config/running/interface/{interface-type}/{interface-name}/loop-detection/shutdown-disable | Displays |
<base_URI>/config/running/interface/{interface-type}/{interface-name}/loop-detection/vlan | Displays |
PATCH URIs | Payload | Description |
<base_URI>/config/running/interface/{interface-type}/{interface-name}/loop-detection | <loop-detection><shutdown-disable>true</shutdown-disable></loop-detection> | Disables the shutting down of the interface by Loop Detection. |
<base_URI>/config/running/interface/{interface-type}/{interface-name}/loop-detection | <loop-detection><vlan>{ui32-vlan-range}</vlan></loop-detection> | Configures the VLAN ID at interface level. |
PUT URIs | Payload | Description |
<base_URI>/config/running/interface/{interface-type}/{interface-name}/loop-detection/shutdown-disable | <shutdown-disable>true</shutdown-disable> | Disables the shutting down of the interface by Loop Detection. |
<base_URI>/config/running/interface/{interface-type}/{interface-name}/loop-detection/vlan | <vlan>{ui32-vlan-range}</vlan> | Configures the VLAN ID at interface level. |
DELETE URIs |
GET, PUT, PATCH, DELETE, OPTIONS, and HEAD operations are supported.
The following example uses the GET option to retrieve the configuration details.
http://host:80/rest/config/running/interface/Ethernet/%220/44%22/loop-detection
None
<loop-detection xmlns="urn:brocade.com:mgmt:brocade-interface" xmlns:y="http://brocade.com/ns/rest" y:self="/rest/config/running/interface/Ethernet/%220/44%22/loop-detection"> <shutdown-disable>true</shutdown-disable> <vlan>40</vlan> </loop-detection>
The following example uses the PUT option to disable the shutting down of the interface by Loop Detection.
http://host:80/rest/config/running/interface/Ethernet/%220/44%22/loop-detection/shutdown-disable
none
