Configures DHCP relay servers.
| URI | Description |
| <base_URI>/config/running/interface/{interface-type}/{interface-name}/ip/dhcp/relay | Configures DHCP relay severs. Valid interface types: Ethernet, Ve. |
| GET URIs | Description |
| <base_URI>/config/running/interface/{interface-type}/{interface-name}/ip/dhcp/relay | Retrieves DHCP relay configurations. Valid interface types: Ethernet, Ve. |
| <base_URI>/config/running/interface/{interface-type}/{interface-name}/ip/dhcp/relay/servers | Retrieves DHCP relay server information. Valid interface types: Ethernet, Ve. |
| <base_URI>/config/running/interface/{interface-type}/{interface-name}/ip/dhcp/relay/servers/address | Retrieves DHCP relay server address. Valid interface types: Ethernet, Ve. |
| <base_URI>/config/running/interface/{interface-type}/{interface-name}/ip/dhcp/relay/servers/address/{ip-address}/use-vrf | Retrieves DHCP relay server address and VRF information. Valid interface types: Ethernet, Ve. |
| <base_URI>/config/running/interface/{interface-type}/{interface-name}/ip/dhcp/relay/servers/address/{ip-address}/use-vrf/{vrf-name} | Retrieves DHCP relay server address and VRF information. Valid interface types: Ethernet, Ve. |
| POST URIs | Payload | Description |
| <base_URI>/config/running/interface/{interface-type}/{interface-name}/ip/dhcp/relay | <servers><address>(ip-address_</address><use-vrf>(vrf-name)</use-vrf></servers> | Configures DHCP relay server. Valid interface types: Ethernet, Ve. |
| DELETE URIs |
| <base_URI>/config/running/interface/{interface-type}/{interface-name}/ip/dhcp/relay/servers/address/{ip-address} |
GET, POST, DELETE, OPTIONS, and HEAD operations are supported.
The following example uses the GET option to retrieve the configuration details.
http://host:80/rest/config/running/interface/ve/11/ip/dhcp/relay/servers
None
<servers xmlns="urn:brocade.com:mgmt:brocade-dhcp" xmlns:y="http://brocade.com/ns/rest" y:self="/rest/config/running/interface/Ve/11/ip/dhcp/relay/servers/21.1.1.10%2C."> <address>21.1.1.10</address> <use-vrf>.</use-vrf> </servers> <servers xmlns="urn:brocade.com:mgmt:brocade-dhcp" xmlns:y="http://brocade.com/ns/rest" y:self="/rest/config/running/interface/Ve/11/ip/dhcp/relay/servers/31.1.1.10%2CRED"> <address>31.1.1.10</address> <use-vrf>RED</use-vrf> </servers>
The following example uses the POST option to configure DHCP relay server.
http://host:80/rest/config/running/interface/ethernet/%221/10%22/ip/dhcp/relay
<servers> <address>10.10.10.10</address> <use-vrf>vrf1</use-vrf> </servers>
None
The following example uses the DELETE option to remove DHCP relay server.
http://host:80/rest/config/running/interface/ethernet/%221/10%22/ip/dhcp/relay/servers/address/10.10.10.10
None
None
