Configures, modifies, or retrieves FRU mail settings.
| URI | Description |
| <base_URI>/config/running/system-monitor-mail | Configures the FRU email alerts.. |
| <base_URI>/config/running/system-monitor-mail/fru | FRU mail settings. |
| POST URI | Payload | Description |
| /rest/config/running/system-monitor-mail/fru | <email-list><email>(string)</email></email-list> | Configures email alerts for the FRUs. |
| PUT URI | Payload | Description |
| /rest/config/running/system-monitor-mail/fru/enable | <enable>true</enable> | Modifies email settings for the FRUs. |
GET, POST, PUT, PATCH, DELETE, OPTIONS, and HEAD operations are supported.
The following example uses the GET option to retrieve the configuration details.
http://host:80/rest/config/running/system-monitor-mail/fru
None
<fru y:self="/rest/config/running/system-monitor-mail/fru">
<email-list y:self="/rest/config/running/system-monitor-mail/fru/email-list/abc@brocade.com">
<email>abc@brocade.com</email>
</email-list>
</fru>
